DsPIC Block
/Digital_Input /Digital_Output_Write /Digital_Output_Read
/ADC_Analog_to_Digital_Converter /Input_Capture /Output_Compare /Change_Notification /External_Interrupt_PWM /PWM_Motor_Output
/UART_Configuration /Tx_Output /Rx_Input /Tx_Output_Multiplexed_For_Matlab-Labview /Interface_Tx-Matlab
/SPI_Configuration /SPI_Input_Output
/CAN_Configuration /CAN_Transmit /CAN_Receive
/Calculus_Time_Step /C_Function_Call /Nop /Software_Reset
Block_Digital_OutputRead.png Block_ADC.png Block_Input_Capture.png Block_Output_Compare.png Block_Change_Notification.png Block_External_Interrupt_PWM.png Block_PWM_Motor_Output.png Block_UART_Configuration.png Block_Software_Reset.png Block_NOP.png Block_C_Function_Call.png Block_Calculus_Time_Step.png Block_IC2_Master.png Block_CAN_Receive.png Block_CAN_Transmit.png Block_CAN_Configuration.png Block_SPI_Input_Output.png Block_SPI_Configuration.png Block_UART_Interface_TxMatlab.png Block_UART_Tx_Output_Multiplexed_MatlabLabview.png Block_UART_Rx_Input.png Block_UART_Tx_Output.png
