DsPIC Block/Master
Master Block
The dialog box parameters differs depending on which microcontroller is used.
Master Block Dialog for the 30f3012 chip, General Tab
Master Block Dialog for the 30f3012 chip, Quartz Tab
Step Based on
PIC
59 Supported devices :
On 30f family microcontroller
You must compute yourself the Instruction Per Seconds using :
With FreqQuartz the frequency of the source (Quartz or internal oscillator, External Clock ...) and with PLL factor set to 1 when PLL multiplication is not used.
For 24, 33 and 32 microcontroller
The Instruction Per Seconds is automatically computed using the Quartz frequency provided. If you activate the PLL mulciplitcation, you have to enter the Desired Instruction Cycle Frequency. From the entered Desired Instruction Cycle Frequency and Clock source Frequency, the toolbox compute the compatible PLL multiplication which provides the closest Instruction Cycle Frequency.
Config Timer
Busy Flag Port
Busy Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
