DsPIC Block/Master
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Master to DsPIC Block/Master: Block is a special page, creates many issues)
Master Block
Master Block Dialog for the 30f3012 chip, General Tab
Master Block Dialog for the 30f3012 chip, Quartz Tab
Step Based on
PIC
59 Supported devices :
For 30f family microcontroller
You must compute yourself the Instruction Per Seconds using :
With FreqQuartz the frequency of the source (Quartz or internal oscillator, External Clock ...) and with PLL factor set to 1 when PLL multiplication is not used.
For 24, 33 and 32 microcontroller
From the entered Desired Instruction Cycle Frequency, the toolbox compute the best PLL multiplication which provides the Instruction Cycle Frequency the closest to the Desired one.
Config Timer
Busy Flag Port
Overload Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
