DsPIC Block
Root
- Master
- Compiler Configuration
- set the size of double data type (32 or64 bits ; default is 32)
Digital I/O
- Digital Input
- Logic Input
- Digital Output Write
- Logic Output, write a value
- Digital Output Read
Peripheral I/O Functions
- Input Capture (IC)
- Change Notification (CN)
- External Interrupt (EI)
- Output Compare (OC)
- PWM Motor Output
Serial Port (UART)
- UART Configuration
- Set UART configuration
- Tx Output
- Tx Input
- Interface Tx-Matlab
SPI PORT functions
- SPI Configuration
- SPI Input/Output
- Input-Output driver for SPI
BUS CAN
- CAN Configuration
- CAN Transmit
- CAN Receive
BUS I2C
- I2C MAster
- I2C Peripheral (as master)
Others
- Calculus Time Step
- Chronograph
- C Function Call
- Nop
- Software Reset
- Reset the microcontroller
