DsPIC Block/PWM Motor Output
Block PWM Motor Output
General Input Enable
Input Periode
Output Channel
Periode
ValMax Periode Calcule
Centered
I Really do not remember what was that for !
Activate the Complementary output of each channel
Gives information :
