DsPIC Block/External Interrupt PWM
< DsPIC Block
Revision as of 20:40, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: The External Interrupt block allow to detect and/or measure Time Pulse (like PWM) on EI ports of dsPIC. This block define function of one EI port only. Use many blocks to use many EI.. =...)
Port
ext Interrupt Priority
Capture PWM
Max capture Time
Safety Margin in %
Change Detected on
Block Ordering Input/Output
