Release Notes
Revision as of 00:34, 12 March 2009 by LubinKerhuel (talk | contribs)
Supported microcontroller :
  • 12/03/2009
  • 01/02/2009: V0.99b
    • added 4 chip...
  • 28/10/2008: V0.99a
