Case Study: Position Control of DC Motor
Revision as of 04:22, 4 February 2009 by LubinKerhuel (talk | contribs)
Subject:
Original Model
Subsysteme1
pid
Possible problems
controller design
PID controller
Overflow
tricks
Saturation followed by abs
set the negative saturation at 0 directly
