Release Notes
Revision as of 14:21, 31 January 2009 by LubinKerhuel (talk | contribs)
Supported microcontroller :
  • Next Release
    • Peripheral added on PIC32 chip : Output Compare (OC), Input Capture (IC)
    • added 4 chip...
  • 28/10/2008: V0.99a
