Remote Control Glider (1m25 wingspan) equipped with sensors (Gyrometers, Accelerometers) and calculators (dsPIC 30f4012).
The RC model airplane
Caracteristics :
  • 1m25 wingspan
  • 400g weight
  • 2 actuated surfaces
Embedded System
Plane during the construction. Differents elements placed inside the planed are showed
Classical RC Material
  • one 6 channel receiver (GWS 610)
  • Two servo motor (HPX )
  • 4 accumulator NiMh placed in the noise of the plane
  • A beeper is also added. The plane can thus emit a sound to provide different indications and after a crash, to help research.
Calculator
Sensors
Micro Electro-Mechanical Sensor (MEMS) are used to estimate the attitude of the plane. Theses sensors have many advantages : They are small, lightweight, low power consumption, robust from the mechanical point of view (i.e. crashproof) and some are precise (rate gyro).
  • rate gyro (ADIS 16080 from analog device)
  • Accelerometers (MMA7260) from freescale
From both the rate gyro and the accelerometers, it is possible to compute the attitude of the plane. For more details on the calculation details, see the page dedicated to the Inertial Measurement Unit (IMU). Weight : Servos GWS HPX : 19g (X2) DC DC converter MCP1252-33X50 - MCP1253-33X50 (3.3V) ==> 2.92g DC DC converter (5.0V) ==> 3.73g Beeper : 3.95g SST SST25VF016B 16 Mbit SPI Serial Flash ==> 3.95g Card dsPIC 30f4012 ==> 17.87g Recepteur RS610 ==> 7g Capteurs Inertiels (2 gyro + 1 accelero) ==> 8.29g
boite maxim DALLAS : 9.35g
total : 85.71g
Recording In Flight Data
  • place a data recorder in the plane (Solutions with SD cards)
  • transmit data to a base-station using a wireless transmission system (Telemetry)
Data Recorder
SST
Telemetry
Bluetooth transmitted data
Model : Two first order system describe respectively the pitch and roll dynamic of the plane.
Angular rate control loop
