Log raw data from sensor
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Data fusion algorithms
Simulation with real data
  • The high pass filter is:
Non adaptative Kalman Filter
Implementation on a dsPIC
Complementary Filter Order 1
Not described yet
Fixed point
Fixed point version id working and can be downloaded in the .zip file at the bottom of the page. Description of the fixed point algorithm will be added here.
  • Simulink models
    • IMU_Simulation.mdl
    • IMU_Simulation_FxdPts.mdl (just added)
    • IMU_dsPIC_30f4012_AlphaBetaFilter_20Mips_FixedPoints.mdl (just added)
  • m script
    • Extract_RawDatas.m
    • Script_Kalman.m
    • Caracterisation_Capteurs.m
  • mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
