Analysis of the Logged datas
5 files corresponding to 5 differents experiments are saved. Figure:RawData shows the result of a logged data. Figure:RawDataSpectre shows the spectral analysis of the same
Simulation based on real data
Non adaptative Kalman Filter
to be continued...
- M script
- Mat files
On-going projects
