Revision as of 13:05, 12 July 2008 by LubinKerhuel (talk | contribs)
  • Complementary filter
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Simulation based on real data
Non adaptative Kalman Filter
  • Simulink models
    • IMU_Simulation.mdl
  • M script
    • Extract_RawDatas.m
    • Script_Kalman.m
  • Mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
