DsPIC Block/CAN Transmit
< DsPIC Block
Revision as of 21:51, 26 May 2008 by LubinKerhuel (talk | contribs) (New page: Write data to a CAN bus The CAN Transmit block allow to send CAN message containing between 1 and 8 bytes on a CAN Bus. The configuration of the BUS parameters are set using the CAN Confi...)
Num CAN
Tx Priority
Each message is assigned to a priority. When the two buffer of the CAN Peripheral contains two message, the message with the highest priority is being sent first. Four priority level exist :
  • Highest
  • High
  • Low
  • Lowest
Identifier Length
  • Standard 11 bits identifier
  • Extended 29 bits identifier
Identifier is a block input
Remote Request
Data Length Code Bits
Error flags
  • Tx Buffer Full
  • Tx CAN Bus Off
  • Tx CAN Bus Passive
  • Tx CAN Warning
Information
