Lets:
- <Tex>\Theta= \arctan \left( \frac{a_z}{a_x} \right)</Tex>
 - <Tex>\Phi = \arctan \left( \frac{a_z}{a_y} \right)</Tex>
The aim of this complementary filter is to provide a method to implement a model on the dsPIC that has been previously improved thanks to the simulation capabilities of simulink. Simulation uses real data logged with the dsPIC peripheral (same electronic circuit, noise etc...)
In a first step, the real data are logged by the first model IMU_LogData. The complementary filter is simulated using the real data in the IMU_simu_RealData. The resulting model is then implemented into the dsPIC in the IMU_ComplementaryFilter model.
Log real data
The model IMU_LogData is compiled and the generated .hex file is loaded into the dsPIC (using the bootloader tinybld).
The quartz and PLL of the dsPIC are choosen in order to have an low UART %error when UART is configured at 115200bps which is the max baud rate available on most computer (Serial port's limitation).
The model sample the data at 1Khz, corresponding to the time-step of 1ms. During 1ms, the UART can send 11 Bytes when configured at 115200 bps (including start and stop bits).We log 3 int16 data (X and Z acceleration ; and Y raw gyro) that correspond to 6 bytes. Adding one protocol byte for each different variable sent, the model send 9 bytes at each time step. Because the model send less that 11 data by time-step, all data will be send and received by the computer that log theses data. If this model send more that 11 bytes within one time step, some data could not be sent and would therefore be lost (it is OK for plotting data but not for use as input data in a Simulink simulation).
The data that get out from the IMU_Sensors block are fixed point data type. They are converted into uint16 using the Store Integer option : in other word, their bits are not modified, but their representation for simulink is now uint16 (thus, their value has changed for simulink !) . They can be sent by the TxOutputMultiplexed block that is able to send int8, uint8, int16, uint16, int32 or uint32 data type.
The dsPIC is connected to the PC COM port (usint an equivalent to Max232 component for level translation) and data are logged using the graphical user interface (open the Interface TxMatlab block, for more information, see examples). The following lines are typed at the maltab prompt to save data into a .mat file :
Simulation based on real data
Data logged in real time from the complementary filter implemented on the dsPIC (30f4012 running at 10MHz). X axis : time in second. Y axis : angle multiplied by 100 (see model)
  Remarks
Programming dsPIC or PIC24 becomes exciting and fun with this toolbox. You do not have to waste your time with configuration of the dsPIC peripherals ! Focus only on simulink simulation, Real time Workshop capabilities, and on fixed point optimization.
Futur work
