DsPIC Block/Output Compare
< DsPIC Block
Revision as of 19:36, 26 May 2008 by 139.124.74.228 (talk) (New page: Output driver for PWM output data =Outline= The Output Compare (OC) block generates PWM impulse on the Output Compare peripheral. There is two entry for each channel. They can be configur...)
Outline
  • Time Up and Time Down
  • Time Up ane Periode
  • Time Down and Periode
With
Interrupt Priority
Output Channels
Channels Input Type
Max/Channels
