Lets:
  • <Tex>\Theta= atan(\frac{z}{x})</Tex>
  • <Tex>\Phi = atan(\frac{z}{y})</Tex>
Log real data
File:IMU LogDataModel.jpg
Simulation based on real data
File:IMU simu RealData.jpg
File:IMU simu RealData Curves.jpg
File:IMU ComplementaryFilter.jpg
Logging dara resulting from this filter running on the dsPIC, we get the following curves :
Remarks
Futur work
