DsPIC Block/Output Compare HW
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Output Compare HW to DsPIC Block/Output Compare HW: Block is a special page, creates many issues)
Block Output Compare
Outline
Output Compare Dialog
  • Allow generation of very fast PWM signal
  • Possibility to set accurately the ADC sampling time at any instant of the PWM period.
  • All PWM channels have the same Period (however, mode and duty cycle can be different)
  • The peripheral will not be able to share the timer it uses with others peripheral
  • Time Up and Period
  • Time Down and Period
  • Time Set and Reset
Synchronisation with the ADC: The ADC can synchronize with the Timer 3. The sampling time starts at the end of the period. When the third mode (Time Set and Reset) is selected, it is possible to set within the timer period the rising and falling instant. This makes possible sampling at any instant of the PWM period. Input block value must be scaled using the following :
With
  • MaxChannel = The literal value (in second) you defined as the max time in the dialog box
  • OCmax = a constant automatically evaluated in the matlab workspace
Clarifying note regarding OCkmax: OCkmax is relevant to the internal chip frequency (typically depending on quartz and PLL used). the dsPIC blockset evaluate this variable in the MATLAB workspace. Type "who" at matlab prompt to list all variable. Get the variable value typing its name "OC1max" (case sensitive). There are two OC blocks : The OC hardware block creates one variable OCmax. The OC block creates multiple variables OC(x)max with x, corresponding to each channel (1, 2 3 or 4)
Output Channels
Channels Input Type
  • 5 : set UP duty cycle and Period
  • 10 : set Down duty cycle and Period
  • 16 : set rise and fall time instant within the period (useful when using ADC)
Periode as block input
Period Max
Related block & Examples
Related block:
Examples:
