DsPIC Block/I2C Master
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/I2C Master to DsPIC Block/I2C Master: Block is a special page, creates many issues)
Block I2C Master
I2C Master Dialog
Ref I2C
Alternative I2C pin
This option is display when the dsPIC has an alternative I2C pin option. All I2C blocks must have the same configuration. Either this option is checked in all of the I2C blocks, neither none of them are checked. Mixing both will result in chosing randomly one of the PIN configuration and may also provide unexpected behaviour.
Sequence
  • S : generate a start condition on the bus
  • Sr : generate a re-start condition on the bus
  • P : generate a stop condition on the bus
  • A and Axxx : send the address of the component of the bus. If followed by a decimal number (like A104) this number is taken as the address. Otherwise, a block input appear noted A1
  • W and Wxxx : write a data of type uint8 on the bus. If followed by a decimal number (like W82) this number is taken as the data being written. Otherwise, a block input noted W1 appears.
  • R and Rnack : Read a data of type uint8 on the bus. R generate an acknowledge. Rnack do not generate the acknowledge. A block output noted R1, R2 ... Rn appears for each R or Rnack present in the sequence.
Example of sequence : ' S A125 W R R P '
Initialisation
Define when the I2C peripheral is configured :
  • When PIC is initialized (only once)
  • When I2C bus is enable (if Enable I2C is checked)
  • Both
  • None
I2C bus frequency
Slew rate active
Activate Slew rate
Enable SMB bus threshold
Output Error flag
