DsPIC Block/C Function Call
Call user defined C function
The C Function Call block allows to include your custom C written functions (that could contain assembly language) into the schematic. It Interfaces your functions with the MathWorks Simulink diagram. The .c file containing the code of the function should be placed in the same directory as the .mdl file. If the c file is in another directory, it must be manually added in the "Simulation Target > Custom Code > include custom c code in generated > source file"
Function Name
Global input size
Input 1 2 3
Output Size
Output type
data type of the output data.
Sample time
-1 means inherited
Function declaration
Function call
- %y represent blocks output
- %u represent blocks input
