Picooz
- One Picooz
- One Atlas
They are built by Silverlit
Picooz
Weight
- EPP : 1.57g
- accumulator : 1.87g
- Electronic board : 0.85g
- tail propeller : 0.08g
- tail motor : 0.63g
- tail motor housing : 0.17g
- tail main bar : 0.37g
- tail paper : 0.02g
main rotor force
Tail rotor force
Accumulator
Onboard electronic
Atlas
Sky Cruiser (NIKKO)
brand new helicopter weight: 23.97g
