DsPIC Block/CAN Transmit
Write data to a CAN bus
Num CAN
Tx Priority
Each message is assigned to a priority. When the two buffer of the CAN Peripheral contains two message, the message with the highest priority is being sent first. Four priority level exist :
- Highest
- High
- Low
- Lowest
Identifier Length
- Standard 11 bits identifier
- Extended 29 bits identifier
Identifier is a block input
Remote Request
Data Length Code Bits
Error flags
- Tx Buffer Full
- Tx CAN Bus Off
- Tx CAN Bus Passive
- Tx CAN Warning
Information
