Hyper Sampling
Revision as of 19:36, 31 August 2010 by LubinKerhuel (talk | contribs) (→‎Related Links:)
RC filter
The Electronics – RC filter
Principle
The filter output signal is
  • Periodic
  • Time invariant
Simulink model file
Results
Looking deeper
Logging Animation
Acknowledgement
