DsPIC Block/UART Configuration
- 1 stop bit
- 8 bits data
- no parity
- no flow control
UART to be used
Baud (kb/s)
UART Speed you want to use. The exact speed will usually not be reach. An error above 4% usually gives no transmission errors. Check the error speed before use.
Tx Rx Alternativ
Tx Interrupt Priority
Tx Interrupt are used when the block "Tx Output Multiplexed For Matlab Labview" is present. This block stores input into a circular buffer. The Tx interrupt get datas from this buffer.
Tx Interrupt
The Microcontroller has an internal 4 bytes buffer TXBUF. "Interrupt on TXBUF becoming empty" will gives fewer but longer interrupt."Interrupt on transfer of every character to TSR" will fullfill the microcontroller internal buffer as soon as there is one empty place. This will result in more interrupts.
TXEN
RX Interrupt Priority
Interrupt Priority
Gives following information : UxBRG register value. The real bit rate achieved by the microcontroller and the error in percent between the real bit rate and the requested bit rate. The max Byte/Step is the maximum number of byte that can physically be sent during one diagram time step. If your schematic send more data throw the UART, somme data will be lost or the real time constraint will be violated (ie, the time step will be longer than expected).
