DsPIC Block/Input Capture
Interrupt Priority
Input Channels
Channels Input Type
 - 3 : is to get both High and low pulse duration
 - 4 : is to get the periode using rising edge
 - 8 : is to get the periode using falling edge
 - 5 : is to get both High pulse duration and periode using rising edge
 - 10 : is to get both Down pulse duration and periode using falling edge
Max/Channels
Define max time in secondes of the largest event tu be measure by the respective channel. Safety margin in %
Changed Detected on
