Current release : 3.7e
- C30 compiler for PIC24, dsPIC30 and PIC33 family (tested with version 3.10b and 3.11b) (download C30 for PIC24 and C30 for dsPIC and install both. downlaod webpage)
An animation of the installation process is available on the Examples page.
