DsPIC Block/Interface Tx-Matlab
Interface PIC-Matlab
Set the connexion of the PC serial port. You can select the COM port used, the baudrate ( select the same used by the dsPIC) and the hardware control flow (usually, set to none if you are using a simple wire. if you use aerial module like bluetooth, you need perhaps the hardware control Flow).
The connexion and Reset button connect and release the COM port. Once the connexion is set, modification of port parameters has no influence. When connecting, some Windows crash if the dsPIC is sending data. If so, disconnect the PIC while pushing the connection button.
The data received are decoded using the PIC - Matalb protocole created and stored into the R matrix. Each column of R correspond to one channel. R growth until its size reach the buffer size (here 50000). Then, oldest data are deleted so as to retain into R the last 50000 data received. R, T_R, Rn, T_Rn are accessible from the workspace. R and Rn matrix contains NaN values. The function padr allow to remove NaN values.
Watch out : When logging data for a long time usinga big buffer size, some data may be lost : As the matrix R is growing,Matlab reallocate memory when the matrix is growing. This memory allocation may take some time and for reason that are still unclear, Seral port lose some datas. Note that Matlab use Java to acces to the serail PORT. Thus, it is not optimal!
