Release Notes
Supported microcontroller :
- Next Release
- Peripheral added on PIC32 chip : Output Compare (OC), Input Capture (IC)
- 16/09/2008 : V0.98fe
- 02/09/2008 : V0.98fc
- 09/08/2008 : V0.98f
- 15/07/2008 : V0.98e
- 18/06/2008 : V0.98d
- Corrected bugs :
 - Corrected bugs :
