Release Notes
compatible chips :
- soon : V0.99a
- 20 Chips added for experimental use: 33fj64GP802, 33fj128GP802, 33fj32GP302, 33fj64GP202, 33fj128GP202, 33fj64GP804, 33fj128GP804, 33fj32GP304, 33fjGP204, 33fj128GP204, 33fj64MC802, 33fj128MC802, 33fj32MC302, 33fj64MC202, 33fj128MC202, 33fj64MC804, 33fj128MC804, 33fj32MC304, 33fjMC204, 33fj128MC204. Add of the Mapping_PIN block for the remappable peripheral function available on theses chips. PWM Motor block NOT WORKING YET on theses chip !
- Correct bug in PWM Motor block that may give rise to error while opening Master block or whild compiling
