Log raw data from sensor
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Data fusion algorithms
Simulation with real data
  • The high pass filter is:
Non adaptative Kalman Filter
Implementation on a dsPIC
Complementary Filter Order 1
Not described yet
Fixed point
Very soon...
IMU_for_dsPIC.zip : All Simulink and Matlab file used with data logged. (updated on 20 august 2008)
  • Simulink models
    • IMU_Simulation.mdl
  • m script
    • Extract_RawDatas.m
    • Script_Kalman.m
    • Caracterisation_Capteurs.m
  • mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
