Revision as of 20:07, 14 July 2008 by LubinKerhuel (talk | contribs)
All files including simulink model, matlab script and data files (.mat) can be downloaded : see the Download section.
  • Complementary filter
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Raw data from the sensor. On this experiment, the IMU box were rotated by 90 degrees with interval of about 5s. File RawDatas_Dynamic_Calibration_40se.mat plotted using the script Extract_RawDatas. Theses raw data are saved in a .mat file and are used to feed a simulink simulation.
Simulation based on real data
Non adaptative Kalman Filter
to be continued...
  • Simulink models
    • IMU_Simulation.mdl
  • M script
    • Extract_RawDatas.m
    • Script_Kalman.m
  • Mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
