- C30 compiler for PIC24, dsPIC30 and PIC33 family (tested with version v3.10b)
 - C32 compiler for PIC32 family (tested with version (v1.02)
Current release : 3.7e
100 supported microcontrolleurs
- [dsPIC Toolbox for Matlab R2006a]
 - [dsPIC Toolbox for Matlab R2006b]
 - [dsPIC Toolbox for Matlab R2007a]
 - [dsPIC Toolbox for Matlab R2007b]
 - [dsPIC Toolbox for Matlab R2008a]
Supported Microcontrolleurs :
