Scope picture of a PWM Signal with a large duty cycle
Scope picture of a PWM Signal with a small duty cycle
Description
PWM Circuit
Bootloader
Simulink models
Common parts
Master block
Bootloader RESET
Model (A): Emission
Sine wave generation
Measuring Time Step
PWM Generation
Model B: Reception
