- 1 Introduction
- 5 Acknowledgement
Let's consider:
![](/w/images/thumb/a/a9/IMU_dsPIC_30f4012_TestElectronics.png/350px-IMU_dsPIC_30f4012_TestElectronics.png)
![](/w/images/thumb/8/86/IMU_dsPIC_30f4012_LogData_Raw.png/350px-IMU_dsPIC_30f4012_LogData_Raw.png)
![](/w/images/thumb/4/47/IMU_RawData_SpectralAnalysis.png/350px-IMU_RawData_SpectralAnalysis.png)
IMU Data fusion algorithms
![](/w/images/thumb/8/8f/IMU_Simulation.png/350px-IMU_Simulation.png)
Simulation with real data
- The high pass filter is:
State Space Approach
- IMU_Simulation_FxdPts.mdl
- m script
- Caracterisation_Capteurs.m
- mat files
Implementation on a dsPIC
Complementary Filter Order 1
Fixed point
- it takes a roll angle, then
Electronic board evolution
Extended IMU algorithm
This IMU is being tested onboard a Remote Control (RC) flying wing. It is destined to become an important part of the autopilot currently under development. For more information, see page :
Acknowledgement
Enable comment auto-refresher
