DsPIC Block/CAN Transmit
Write data to a CAN bus
Num CAN
Tx Priority
Each message is assigned to a priority. When the two buffer of the CAN Peripheral contains two message, the message with the highest priority is being sent first. Four priority level exist :
- Highest
 - High
 - Low
 - Lowest
Identifier Length
- Standard 11 bits identifier
 - Extended 29 bits identifier
Identifier is a block input
Remote Request
Data Length Code Bits
Error flags
- Tx Buffer Full
 - Tx CAN Bus Off
 - Tx CAN Bus Passive
 - Tx CAN Warning
Information
