Main Page
Revision as of 21:58, 12 June 2008 by LubinKerhuel (talk | contribs)
List of all Blocks composing the PIC/dsPIC blockset for Simulink Download the Toolbox List of Examples Pricing Review Forum
Legend The blocks added to the simulink® library allow to connect most of the PIC24, dsPIC30 and dsPIC33 peripherals (PWM, ADC, IC, OC, SPI, I2C, CAN, UART ...) to any other Simulink blocks C code generated for theses peripheral is merged to the C code generated by the Real Time Embedded Coder® toolbox.
It makes real time Monitoring and debugging easy. It also allows to log data into the matlab workspace. The logged data can be used to feed a simulink model for simulation. Thus, real microcontroller input data recorded (from ADC, IC...) are used for the simulink simulation or .m script file allowing to test or improve the simulink model using real data logged in real condition. Once you have tune the math part of your model, you can then reprogramme the microcontroller with the new improved model. The simulation result will be very close to the real model running in the microcontroller since input data comes from the same peripheral and the microcontroller's running model is equivalent to the PC simulation model.
Legend Capabilities of the blockset.
Possible target are most of the dsPIC30f, dsPIC33, PIC24H and few PIC32. ( see detail on the download page) Supported Chip : {PicList}
