DsPIC Block/Digital Input
< DsPIC Block
Revision as of 19:52, 26 April 2010 by LubinKerhuel (talk | contribs)
The Digtal Input block reads the logical value of the selected microcontroller pin.
Port
- Port used
Pin
- Pin used, start at 0 and is defined in vector form allowing several Pin to be read at the same time.
- -1 is inherited
