Release Notes
- 17/11/2009: V3.2
- Better integration into windows Vista 0x64 bits
- 16/09/2008 : V0.98fe
- 02/09/2008 : V0.98fc
- 09/08/2008 : V0.98f
- 15/07/2008 : V0.98e
- 18/06/2008 : V0.98d
- Corrected bugs :
 - Corrected bugs :
