DsPIC Block/PWM Motor Output
Main Dialog Box Parameters
General Input Enable
Input Periode
Output Channel
Periode
All temporal value provided to the bock input must be uint16 variable. The integer variable PWMmax created automatically in the workspace code for the time defined in Periode. Thus, any temporal value at block input must be multiplied by <tex>\frac{PWMmax}{Periode}</tex>. integer value at block input = <tex>T_{set} * \frac{PWMmax}{Periode}</tex>
With
for example, a 1ms is coded with (Periode is set to 20ms : <tex>20*10^{-3}</tex>):
<tex>1*10^{-3}*\frac{PWMmax}{20*10^{-3}}</tex>
ValMax Periode Calcule
Centered
Gives information :
Dead Time TAB
Dead Time A - B
Dead Time Info
Dead Time PWMx Active
Dead Time PWMx Inactive
