DsPIC Block/PWM Motor Output
Main Dialog Box Parameters
General Input Enable
Input Periode
Add the Periode Input. When the PWM periode is not constant, this input allow to control the PWM periode dynamically. Note that only one Input Periode appears as this periode is common for all PWM channels. If your application require different input period, you should use the Output Compare (OC), or Output Compare Hardware (OC_HW) block that are able to generate PWM signals with differents Periode for each channel.
Output Channel
Periode
ValMax Periode Calcule
Centered
Gives information :
Dead Time TAB
Dead Time A - B
Dead Time Info
Dead Time PWMx Active
Dead Time PWMx Inactive
