Release Notes
Supported microcontroller :
- demo Version V3.0 had a limitation that (will) make it not workable from October 17th 2009
- 16/09/2008 : V0.98fe
- 02/09/2008 : V0.98fc
- 09/08/2008 : V0.98f
- 15/07/2008 : V0.98e
- 18/06/2008 : V0.98d
- Corrected bugs :
 - Corrected bugs :
