DsPIC Block/I2C Master
Ref I2C
Sequence Specify the I2C bus sequence. The sequence is enterred as text, between single quote 'xxx'.
Initialisation
 - Both
 - None
I2C bus frequency
Slew rate active
Activate Slew rate
Enable SMB bus threshold
Output Error flag
