Release Notes
Revision as of 01:05, 8 July 2009 by LubinKerhuel (talk | contribs)
Supported microcontroller :
  • 08/07/2009: V0.99g
  • 04/06/2009: V0.99f
  • 04/06/2009: V0.99e
  • 19/04/2009: V0.99d
  • 12/03/2009 V0.99c
  • 01/02/2009: V0.99b
    • added 4 chip...
  • 28/10/2008: V0.99a
