DsPIC Block/Rx Input
Block UART Rx Input
The Rx Input block receive one byte (uint8 scalar) at each step. If several bytes have been received during the previous time step, only the first one will be available in the current step execution time.
If no bytes have been received, the is set to the output default value. The block can be a blocking function : stop the step execution until one byte is received ( not recommended due to possible step violation).
UART Used
-1 for inherited
Blocking Function
Output Default
If no data has been received, the block will output the value defined here. Received Output Flag
  • 1 if one byte has been received,
  • 0 if no data has been received ; the output value is the "Output Default" value.
