Release Notes
Supported microcontroller :
- Bug corrected on the ADC: Blocks output are always in the increasing order. If you set in the ADC channels [5 3 2], the first output blocks is channel 2, the second is channel 3 and the last is channel 5, despite the wrong output port label. Output port label is now shows in the right order. (no change on block's output).
