DsPIC Block/Change Notification
The Change Notification (CN) block allow to detect a change on one or several inputs. This peripheral can also be used to measure the duration of a pulse (like PWM) on all CN ports of dsPIC / PIC24. Note that this block used in PWM input mode is less robust than Input Capture peripheral.
Input Channel
Specify Change Notification channel(s) (CN) starting from 1. Specify multiple channels as a vector. This will also set the block's number of output.
Channel Input Type
- 1 : get the High pulse duration
 - 2 : get the Low pulse duration
 - 3 : get both High and low pulse duration
 - 4 : get the periode using rising edge
 - 8 : get the periode using falling edge
 - 5 : get both High pulse duration and periode using rising edge
 - 10 : get both Down pulse duration and periode using falling edge
 - The position value in the vector refers to corresponding channel defined in "Input Channels".
Max/Channels
Safety Margin in %
Change Detected on
Pull up
for each channel, 1 mean internal Pul-up resistor connected ; 0 mean Pull up not disconnected.
