Implementation of a miniature Inertial Measurement Unit (IMU) on a dsPIC microcontroller using Mathworks (tm) rapid prototyping tools. Simulink is used for both simulating and generating embedded code downloaded onboard the microcontroller. This IMU estimates pitch and roll angles using two Micro Electro Mechanical Systems (MEMS) sensors: Rate gyro and Accelerometers.
- 1 Introduction
 - 4 IMU based on a 6 DoF sensor board (3 gyro, 3 accelero)
 - 5 On-going projects
The micro Inertial Measurement Unit (IMU) It is an attitude indicator (ADI) or artificial horizon also called gyro horizon that estimates its attitude about both axis : pitch and roll. The electronics parts are:
The first part settle the inherent problem of angle estimation from inertial sensors using MEMS. Then, a first IMU based on a 5 DoF electronics sensor board is presented. Its electronics sensor board is described. Raw data measurement are then logged and different data fusing algorithms are compared with simulation based on previous real data logged. The implementation of the simulink model using a dsPIC is then described. I am using the rapid prototyping tool described on this website (dsPIC blockset for Simulink) allowing generating the .hex code file for the microcontroller directly from the simulink model file with a one push button procedure.
This IMU based on 5 DoF sensor board do not take into the effect of a rotation about the relative yaw axis. This rotation have can have effect on the estimation of the absolute pitch and yaw angle due to angle coupling and it is necessary to take this one into account if the IMU is to be used onboard a plane. This problem is described and an IMU based on an 6 DoF sensor board is presented.
Let’s consider:
- The more the angle estimation rely on the accelerometers, the more the angle estimation is subjected to error (due to acceleration) and to noise (from accelerometers sensor)
 - The more the angle estimation rely on the rate gyro, the longer the time for the angle estimation to converge to the correct value (Less robust to error; for example at initialisation time or after one of the rate gyro saturates).
The overall sensor board is supplied with a single stabilized 5V generated with a microchip MCP1252-33X50 component. The 2.5V alimentation required by the accelerometer chip is provided by the 2.5V Voltage Reference of one rate gyro. The low current requirement for the accelerometers does not disturb the rate gyro. Each rate gyro has two unused analog input. Thus, the two gyros have 4 analog input, 3 of which are used to convert the three analog values ax, ay, and az from the accelerometer. This sensor board transmits the 5 measurements (3 acceleration + 2 rate gyros) to the microcontroller through a digital SPI bus.
IMU Data fusion algorithms
Simulation with real data
- The high pass filter is:
State Space Approach
The state space approach is equivalent to 2nd order complementary filter with the advantage of providing explicitly the estimated rate gyro bias and the unbiased angular rate of the system. The structure is a state space observer. The two states are the angle estimation and the gyro bias. The matlab function acker allows placing (through the gain K) the pole of the observer, defining the convergence of both the angle estimation and of the rate gyro bias. Defining a high speed convergence rate make the output more sensitive to the acceleration measurement, inducing noise from the accelerometers and sensitivity to the own acceleration of the unit that induce false angle estimation. A low convergence rate will make the bias estimation of the rate gyro very slow.
It is possible to set a different convergence rate for the two states. The gain K is static in this version. Using a variable gain K based on sensor noise measurement and system’s own dynamic would result in the implementation of a Kalman Filter. However, added calculation are not worth because the characteristics of the system are fixed (Dynamic of the vehicle is fixe, and sensor noise is stationary). The gain obtained using a kalman filter does not justify its complexity.
 - IMU_Simulation_FxdPts.mdl
- m script
 - Caracterisation_Capteurs.m
 - mat files
Implementation on a dsPIC
Complementary Filter Order 1
Fixed point
Log raw data from the 6 DoF sensor board
One rate gyro has been added on the sensor presented above to measure the yaw rate.
- Problem of logging data is now different
 - the two gyro gain change (unexpected!)
 - data analysis
State space approach with non linearity
- biais analysis is different : develop (do not use magnetic field)
On-going projects
I am planning to use this IMU in an autopilot for remote controlled glider ( as previous project described on my french website : http://lubink.free.fr)
Point to clarify, error, remarks ? Please, leave your comment on the forum!
