Implementation of a miniature Inertial Measurement Unit (IMU) on a dsPIC microcontroller using Mathworks (tm) rapid prototyping tools. Simulink is used for both simulating and generating embedded code downloaded onboard the microcontroller. This IMU estimates pitch and roll angles using two Micro Electro Mechanical Systems (MEMS) sensors: Rate gyro and Accelerometers.
- 1 Introduction
 - 4 IMU based on a 6 DoF sensor board (3 gyro, 3 accelero)
 - 5 On-going projects
The micro Inertial Measurement Unit (IMU) It is an attitude indicator (ADI) or artificial horizon also called gyro horizon that estimates its attitude about both axis : pitch and roll. The electronics parts are:
The first part settle the inherent problem of angle estimation from inertial sensors using MEMS. Then, a first IMU based on a 5 DoF electronics sensor board is presented. Its electronics sensor board is described. Raw data measurement are then logged and different data fusing algorithms are compared with simulation based on previous real data logged. The implementation of the simulink model using a dsPIC is then described. I am using the rapid prototyping tool described on this website (dsPIC blockset for Simulink) allowing generating the .hex code file for the microcontroller directly from the simulink model file with a one push button procedure.
This IMU based on 5 DoF sensor board do not take into the effect of a rotation about the relative yaw axis. This rotation have can have effect on the estimation of the absolute pitch and yaw angle due to angle coupling and it is necessary to take this one into account if the IMU is to be used onboard a plane. This problem is described and an IMU based on an 6 DoF sensor board is presented.
Let’s consider:
A trade-off has to be found:
- The more the angle estimation rely on the accelerometers, the more the angle estimation is subjected to error (due to acceleration) and to noise (from accelerometers sensor)
 - The more the angle estimation rely on the rate gyro, the longer the time for the angle estimation to converge to the correct value (Less robust to error; for example at initialisation time or after one of the rate gyro saturates).
Thus, the fusing algorithm tuning should take into account the dynamic of the system.
The overall sensor board is supplied with a single stabilized 5V generated with a microchip MCP1252-33X50 component. The 2.5V alimentation required by the accelerometer chip is provided by the 2.5V Voltage Reference of one rate gyro. The low current requirement for the accelerometers does not disturb the rate gyro. Each rate gyro has two unused analog input. Thus, the two gyros have 4 analog input, 3 of which are used to convert the three analog values ax, ay, and az from the accelerometer. This sensor board transmits the 5 data (3 acceleration + 2 rate gyros) to the microcontroller through a digital SPI bus.
Data fusion algorithms
Simulation with real data
- The high pass filter is:
State Space Approach
Implementation on a dsPIC
Complementary Filter Order 1
The estimated angle using accelerometers (blue curve) is quite noisy. However, it steady value is correct. The estimated angle relying on the integration of the gyro is clean but drift (red curve). Note that the dsPIC has just been switch on and the High pass filter of the pseudo integrator of the gyro has not yet removed the remaining DC bias of the gyro. The DC bias of the Gyro has probably changed due to non constant temperature. Thus, the integrated angle drifts slowly from its real value. The green curves that use both data is clean and drift free. Its dynamics is as fast as the gyro dynamic. Note that at the beginning, the High pass filter (with a higher bandwidth than the gyro pseudo-integrator high pass filter) has not yet removed the gyro bias. However, at the end of the animation (11 seconds long: from 3, 5 to 14, 5), both curves (blue and green) are merging as in the simulation.
Fixed point
 - IMU_Simulation_FxdPts.mdl
- m script
 - Caracterisation_Capteurs.m
 - mat files
Log raw data from the 6 DoF sensor board
One rate gyro has been added on the sensor presented above to measure the yaw rate.
- Problem of logging data is now different
 - the two gyro gain change (unexpected!)
 - data analysis
State space approach with non linearity
- biais analysis is different : develop (do not use magnetic field)
On-going projects
I am planning to use this IMU in an autopilot for remote controlled glider ( as previous project described on my french website : http://lubink.free.fr)
Point to clarify, error, remarks ? Please, leave your comment on the forum!
