Flex Board Blinking Led
Model Configuration
UART is configured with its maximum speed (for the PC) i.e. 115200 bauds. This UART speed cannot be achieved without enabling the dsPIC clock multiplier PLL. Without PLL, the microcontroller run at 2MIPS and the UART speed error (read from the UART configuration block) is of 8.5%. Therefore, PLL is activated. The targeted speed must be compatible with the UART baud used. With a configuration of 9.2MIPS, UART has a speed error of -0.17% (The real baud is 115000 ; error is : <tex>\frac{115000 - 115200}{115200} = -0.0017</tex>)
 - the variable 61 define which data is send to the PC :
<tex>\frac{4500}{18399} = 0.25</tex>
