Revision as of 14:45, 20 August 2008 by LubinKerhuel (talk | contribs)
Log raw data from sensor
  • model time-step is 1ms
 >> datas = [T R]';
 >> save mydatafile datas;
Data fusion algorithms
Simulation with real data
The raw data feeds a block called Sensor Calibration. This block removes bias of rate gyro and accelerometers. Because we use the arctan function, the accelerometer axes do not need to be scaled.
Three angle estimation method are tuned and compared:
Non adaptative Kalman Filter
to be continued...
  • Simulink models
    • IMU_Simulation.mdl
  • M script
    • Extract_RawDatas.m
    • Script_Kalman.m
  • Mat files
    • Simulink_Static.mat
    • Simulink_Static_60s.mat
On-going projects
